RE: THE OMP KATANA ARF's HERE!!!!
Once again you have disappointed me. First you sent the wrong gear. Now I find out you have an improved version coming out that was not mentioned when I ordered my plane a couple of weeks ago. Your answer on the throttle servo cable is unsatisfactory. In order to get the cable through the wing into the compartment you must cut a hole in the main wing spar. I do not consider this a satisfactory solution. I am wondering if anyone just cut a hole in the fuselage to at least get it over to that side of the wing.
