Your answer on the throttle servo cable is unsatisfactory. In order to get the cable through the wing into the compartment you must cut a hole in the main wing spar. I do not consider this a satisfactory solution.
So pick a spot that's not through the spar... or come up with your own solution.
N
ow I find out you have an improved version coming out that was not mentioned when I ordered my plane a couple of weeks ago.
From the very beginning OMP said they were gonna make some improvements and this was just a trial run of the Katana. Have you looked around here? Does OMP not have the best customer service you've ever seen? They even have a forum for their stuff and you can talk directly to them any time you want. They will fix anything that is truly wrong so long as it's not a frivolous little gripe. Don't jump the gun, man.
