RE: Methanol Question
Klotz benol fuel is available at most speed shops and is compatible with methanol.
The amount of oil based as percentage volume of total fuel mix is based on the engine size. As you increase the engine displacement you can get away with slightly less oil than smaller size 2 stroke engines.
For an engine above .90 size 16-18% oil is sufficient.
For engines .90 and below 18-20% oil is adequate.
