RCU Forums - View Single Post - Primer question
Old 07-20-2004 | 09:23 AM
schroedm's Avatar
schroedm
Default RE: Primer question
I finish it all off first then fly. My approach to this is that you're more likely to introduce a problem by pulling all the gear out and re-installing it (which is mostly necessary if spraying a model). As far as I'm concerned once you've done that the first flight after it is painted is the same as the very first flight the model ever had anyway!
Rgds,
Mark
