And cyberspace. For your information, there is absolutely nothing wrong with my engine :stupid:
I will sell my engine with mufflers, no ignition or prop drive. We can discuss shipping. The previous owner dropped it while installing in the plane and broke a small section off of two cylinder cooling fins. (In most cases when hitting the ground at speeds excessive to 80 mph there's not much left, it gets wiped off onto the ground. (No ignition, prop drive, minus a few fins).
If your going to troll the board and stir up the pot, stir the whole pot and get the whole story. If you care to do a search on the whole story, I did an angine swap on my Edge.
I decided to leave my old ignition in the plane because there is nothing wrong with it, I used the prop hub and bolts because there was nothing wrong with them, and I put a relatively low time carb on the engine because it was fine. Have you ever been in competition and on the road and need spare parts. I have
Now I have a spare ignition, carb and prop hub with bolts if I need them. What's wrong with that, and what IS your point :spinnyeye
Maybe spectrumhobbies sells engines...
