Reflex XTR Raptor 50 setup difficulty (Or not?)
Hello,
I am trying to learn to fly heli's in Reflex XTR but seem to be having problems setting up the Raptor 50 in there. I am using a Futaba 6XAS as the remote, have it in HELI mode on the remote's computer.
I was under the impression that a gyro for a heli is supposed to hold the tail steady, i.e. prevent it from swinging left or right during a hover, climb, or descend..... problem that I am having is that the tail never stays put... it is always swinging around either way... no matter how much I play with the gyro settings in XTR, it doesnt seem to change anything. During flight... like figure eights... it just goes with the flow... coptor flies sort of like an airplane... stays pointed in the correct direction..... which means that if I bank the coptor to the right... pull op on the elevator, it turns just like a plane.
How do you have YOUR raptor setup in XTR, or is what I am experiencing correct?
