RCU Forums - View Single Post - Adjusting a Ryobi 31cc carb
Old 07-20-2004 | 01:42 PM
rcglert's Avatar
rcglert
Default RE: Adjusting a Ryobi 31cc carb
I think you are seeing the restrictor mechanism that are on some carbs. Take a needle nose and pull the red and white assembly off of the carb. Under this, should be your low and high end needles. The other idle screw you mentioned sounds like the idle stop screw. This too can be removed if you like since you will need the butterfly to close fully anyway.
Hope this helps,
Tom
