RCU Forums - View Single Post - Installing nylon hinges
Old 07-20-2004 | 02:20 PM
Gringo Flyer's Avatar
Gringo Flyer
My Feedback: (18)
Default Installing nylon hinges
I have only used CA hinges in the past but am installing dubro nylon hinges on my newest plane. I know that they are suppossed to be installed with epoxy. How much epoxy is enough and how do you keep it off of the monokote and in the joint of the hinge? Also, is it necessary to put a toothpick or needle through the hinge after installed? If you use a toothpick to you wick it with CA too? Not sure why I went with nylon hinges, I guess just to learn something new. I think the CA are a lot easier to use.
