RCU Forums - View Single Post - AbuFletcher's EIII
Old 07-20-2004 | 07:01 PM
abufletcher's Avatar
abufletcher
Default RE: AbuFletcher's EIII
BTW, here's a few of the niceities of the model that don't come across in the photos above.
1. The joy stick moves with the elevator (in the hand of the pilot).
2. The pilot's torso moves slightly with elevator and rudder.
3. Both rudder and elevator cables exit at the same location as per the original.
4. The landing gear is fully functioning independent suspension like the original.
5. The Rx battery is hidden inside the torso of the pilot and the cable exits through his sleeve.
6. The lower end of the joystick exits through the bottom on the plane then the cabling reenters.
7. I have simulated the stitching along the bottom on the fuse (white painted staples)
8. The fuel fill line is at the scale location for the forward fuel tank.
Maybe I can get a few photos of these too.
