ORIGINAL: CARS II
300 flights, It must be some kind of record. What I have I got it used I'll say about 1/2 way used, I had some problems with the carburetor getting stock in the body but solve that little problem with some sanding paper after that and now the engine is running just fine haven't had any other problems with the carb. so far, I'm burning Power Master's 10% with 1 oz. of turbine oil a gallon.
CARS II
i know its a old thread.. u say u add 1oz oil to per gallon.. im using wildcat premium 10%nitro 18% syn/castor oil.. i add 5oz of racing castrol to per gallon.. is this tomuch oil? the engine does smoke alot! or does turbine oil not require as much added?
