RE: Crashed plane... what else should i check?!
Leaks in the fuel tank or around it due to drying out or cracking, bent-pushrods or partially broken pushrods, battery life of both the receiver and transmitter because if its been sitting awhile, the battery may not be able to hold a charge anymore, loose wiring, faulty antenna, clogged fuel lines, dirt in tank, and i'm sure you'll get a lot more suggestions soon ....
