ORIGINAL: Johng
ORIGINAL: razorice79
i sent you a PM, but just in case.. .060 would be about the thickeness of a piece of notebook paper? i just looked at my os91 and it had like 1/8-1/16th of a inch gap at full throttle. and its been cutting out after idling for 30 secs+/- when i full throttle it for take off. it runs fine at full speed.. does hesiate and blows little xtra smoke before cutting out.. and after reading this thread i think i know why...[8D]
HOLD ON THERE. 1/16 of an inch is .062". That is, .060 is almost exactly 1/16 of an inch. A lot thicker than a piece of paper. So, if you have a piece of 1/16 ply or a length of 1/16 music wire, they'll probably do as a feeler to set the low speed needle.
ROGER DAT! i meant to say it was like 1/8th-1/4 inch open before i changed it...i just turned the screw in like 2 full turns to get the 1/16th inch... will run it tomorrow.. [sm=punching.gif]
