RE: Crashed plane... what else should i check?!
Please check if engine has dirt in it ... usually does. Simple way to clean is remove carb and flush that with alcohol (not JD ok!!!) and if u r lazy then just open the back plane and plug and flush with alcohol (Absolute vodka is good).
