LST Throttle Return Spring is a Godsend!!!
I am having problems with my radio cutting out intermittently on my LST. I think it maybe caused by a bad switch or due to the fact that I am using AA batteries in the stock battery holder which I am going to investigate tonight. Anyway, since Losi included the throttle return spring, every time I lose power all that happens is that the trunk goes to idle. Do not remove the spring, it has saved me several times already. Has anyone else had problems with the power cutting out? I have tried changing channels on the radio and the problem stays the same.
Chris
