RCU Forums - View Single Post - Wheel pants assembly.
Old 07-19-2002 | 03:55 PM
RussianFlyer's Avatar
RussianFlyer
Default Wheel pants assembly.
Hello,
I have recently finished a Sig Somethin' Extra and am now up to the stage in the manual where I have to put the wheel pants together. The manual states that the cut outs in the wheel pants for the wheels, and the mounting bolts need to be trimmed out with a dremel tool. Is there any other way to cut the wheel pants othere than using the dremel?
I also installed a Dubro Tailwheel bracket instead of the stock wire gear in the rudder. How should the tailwheel be attached to the rudder? I am considering drilling a hole in the bottom of the rudder and reinforcing it with some fiberglass cloth. Then I would be able to just bend the end of the wire going from the tailwheel to the rudder and insert it into the hole. Will this be a good way of doing it, or are there some other ways to attach the tailwheel steering to the rudder?
Thanks in advance. Also, what glues can be used to attach the canopy? RC-56?
