RCU Forums - View Single Post - how much hp can it take??
Old 07-21-2004 | 05:13 PM
pb_paulie_b's Avatar
pb_paulie_b
Default RE: how much hp can it take??
hi bill! thanks for your input[sm=thumbup.gif] so after all that i'm only around .5 hp higher than when i started? i spoke with mr.hanson about adding a pipe to my ride and he told me that i'd gain at least 1 hp with that alone. also with the poly oxide, the man at the fuel plant just recommended that i not go over 10%. you are correct that my car is a lil slower off the line but not much more than before i threw all that stuff on the motor. when the power "hits" it doesn't matter where i'm at the tires break loose. i just compensate with the steering. it's still very drivable. the car is a blast. also you obviously know a lil' something, i can have any fuel mixed up i want. what is your opinion on the best fuel? right now cooling is not a problem and keep in mind i'm able to raise and lower compression at will.
p.s. the 125's are making 42hp now. thats 3 cc per hp.
