RE: Help with hooking up radio to servos.
Use a "Y" connector. Plug the servos into the "Y" and the leg of the "Y" into the aileron slot in the receiver. Check the movement of the servos to be sure they are going in the proper direction. If not, reverse that channel (should be channel 1 for Futaba).
