RE: Am I doing right?
I would suggest glassing it now. The glassing will normally take care of it. When you sand the fiberglass after you will most likely see some other small imperfections. At that point, if any imperfections show up, use the spot putty. Just make sure you let the spot putty dry completely as most of them tend to shrink a little when drying.
