Ben, re- SkyJet, crow on ailerons how much did you dial in on your Interceptor? thats a good suggestion and I will definetely try that if the 90 degree flaps does not help.... idle speed on engine is fine as is CG. the SkyJet is very clean aerodynamically except for the fixed gear... its suprisingly quick eg 160-180 mph if opened up
