Incedence on bipe wings??
I have four large bipes and all required about 1.5 degrees less angle of attack on the upper wing than the lower wing had. If possible, try to leave your plane so that you can make minor changes on your first flights. It is amazing how as little as 1/2 degree change on the upper wing can effect the flyability of the model.
