RCU Forums - View Single Post - Balsa USA enforcer
Old 07-22-2004 | 04:03 PM
  #217
chuck0306's Avatar
chuck0306
Default RE: Balsa USA enforcer
I agree that the Enforcer is very easy to fly. No bad habits, flies slow with that big thick wing and typical low speed stall characteristics of a delta. Should be no problem for you if you can handle any intermediate plane. I increased the length of the nose gear slightly to help it break from the runway smoothly on take off. A neutral angle of attack with the symmetrical airfoil will require some up elevator to nurse it off the ground. I probably have about 1/2" travel on the surfaces with a little less on the dual rates. Relax and enjoy it.
Chuck
