RE: Near crash --- has this happened to you ?
Yep, been using the iron more than I ever figured I would, that and some ca like Righty was mentioning. Also, check the integrity of the rubber bands holding the wing on, especially after a "bouncy" landing while shooting touch n go's.. I have had one break, then during a loop on the same flight, the wing came loose (you could hear it "rattle" or flutter while under the bottom of the loop), and it skewed a little to one side, causing the aileron to jam.
