RE: Problem with saving a model number
When you change model types in a model memory, the radio resets that memory to factory defaults. You need to store your heli stuff in a model memory and then switch to a different memory to set up another aircraft or heli. The 662 radio has 6 model memories. Each one can be either air or heli.
RTFM Chapter 6 Index 6.5 Model Selection
Fritz
