RCU Forums - View Single Post - Fuel smells burnt
Old 07-24-2004 | 11:17 AM
Campy's Avatar
Campy
Default RE: Fuel smells burnt
The black fuel residue sounds like the muffler to the engine connection may be a little loose. Check the bolts and make sure they are tight. While you are at it check the other bolts on the muffler also. Many people have lost mufflers from them comming loose/off in flight.
If the muffler is loose, that may also be the cause of "the miss".
