RE: Interference with Gas engine
hello
i knew someone that had a simular problem turned out to be the shield on the sparkplug wire ,he bought a new moduel and the same thing happened it turned out that was bad also ,it abouy drove him nuts ! make sure its a resister type plug if it is try changing it also you never know ? anyway thats my two cents worth good luck!
stan
