RCU Forums - View Single Post - Tower Trainer .40 cg
Old 07-24-2004 | 09:13 PM
bingo field's Avatar
bingo field
Default RE: Tower Trainer .40 cg
http://www2.towerhobbies.com/cgi-bin...?&I=LXCAS2&P=0
SPECS: Wingspan: 62" (1575mm)
Wing Area: 698 sq in (45sq dm)
Wing Chord: 11.25" (285.75mm)
Weight: 5 lb (2268kg) assembled
Wing Loading: 17 oz/sq ft (52g/sq dm)
Fuselage Length: 51.5" (1308mm)
Airfoil: Flat Bottom High-Wing
*Center of Gravity: 3-1/2" (89 mm) Back from the wing's leading edge
at the fuselage
Control Throws- High Rate Low Rate
Elevator: Up & Down 1/2" (13mm) 3/8" (9.5mm)
Rudder: Right to Left 1" (26mm) 1" (26mm)
Ailerons: Up & Down 5/8" (16mm) 1/2" (13mm)
Width of fuselage- 3 3/8"
