RE: 3W-100 B2
The carb has a pump inside - no external pumps required. Take a look at your fuel line as you flip the prop with the choke on and ignition off. If it doesn't pull fuel easily from the tank with each flip of the prop, something is wrong. Look for an air leak in the fuel line from the tank.
