Hitec digital servoes not working on y harness
I only have an old analog volt/ohm meter but will second Gill's readings.
Called Hitec this morning and they said they don't recommend using Y harnesses. Well then start making 15-20 something channel receivers to handle all the servos in the larger planes (40%), and radios with enough mixes to get them all to work. I told them my Futaba stuff worked fine (with their servos) and should probably switch back.
