Thanks Terry! You helped out a ton on getting that thing done
I went with a little expo and never did switch off the recommended minimum throws, we will see on the next flight when I start to do more with it.
David, Ill reword it so its better, with the ECU off I get alot of range, with it on I lose some, not as much as I did the first time, I think I have the ant. mounted in a good spot now to clear it better. With it running I lose a little bit more, I dont remember the measurements now, I think it was around 3.5-4/10 of a mile not running, and 2.5/10 of a mile running, on the worst range side with the model 1' off ground.
