RE: Is the Sig Somethin' Extra ok for me?
The se is fine, just turn the rates down and have someone experianced fly it first. At the recommended settings the roll rate will scare you. Along with the SE, I would recommend a couple profiles for your second plane. With the rates turned down real low they are just like a trainer. Once you get used to it turn up to max and there is a plane you will have a tuff time out growing. ie... Morris Sledge 540, EF Edge 540, Morris Top Cap, Carl Goldberg Extra, etc.... Easy to build from kit, easy to repair. Very light so a .46 will give you extraordinary vert.
