RCU Forums - View Single Post - Balsa Size Problems
Old 08-21-2003 | 09:07 AM
LouW's Avatar
LouW
Default Balsa Size Problems
The simplest way to make the size you want is to laminate a 3/16x3/4 and a 1/8x3/4. There are several adhesives that may be used. I would probably use ambroid as it dries slow enough to allow some repositioning for alignment and won’t swell the wood. However other choices would include thick CA, contact cement, aliphatic resin (tite bond II), etc. To use CA, put little poki dots of thick CA on one side only, then carefully align the other piece and press together. Once you press the two pieces together, they will bond instantly and can’t be moved. To use contact cement, apply a thin coat to each piece and let dry. Again carefully align the pieces and press together. The bond is instant. To facilitate positioning, I would cut a strip of waxed paper to fit between the pieces until they are in position, then carefully slide the strip out. They will bond as they come in contact. Finally to use tite bond, apply the adhesive to one strip only then press together. The pieces can be moved around to align. Apply pressure by using weights such as a stack of books and let dry overnight. The pressure is important as the water in the tite bond will tend to swell and warp the pieces without the pressure.
As to removal of the tail from the superstar, suggestions on that would require a look to see what was there. Your description in the previous post left me a little puzzled. I don’t know what a “rubber, super glue, foam like” stuff would be. Whatever it is, an exacto knife, heat from a soldering iron, or a dremel tool should be able to remove it.
Your dilemma is pretty common for folk who begin with ready built models. Unfortunately this hobby always involves crashes and the ability to make repairs is an essential part of it. If you plan to continue for the long haul, I suggest you build your next airplane from a kit. That way you will begin to accumulate the skills and tools to face the many challenges that always seem to come. If you build it you can fix it. In the mean time we will try to help in any way that we can.
