RE: Ring Replacement Question...
Steve,
If Frank has a ring for your engine and nothing has changed in size (over-bore, Etc.), you just need a standard size ring and you will not be asked to send your sleeve in.
Frank has ready-to-use rings for many engines; not only tailor made ones.
His ring will cost less and is likely to last longer than an OEM unit.
