RCU Forums - View Single Post - Epoxy Reducer?
Old 07-26-2004 | 09:12 AM
PlaneKrazee's Avatar
PlaneKrazee
My Feedback: (14)
Default RE: Epoxy Reducer?
As stated, rubbing alcohol should not be used because it contains up to 30% water. Water, if trapped in epoxy will not evaporate. It can cause bubbles and pin holes in your fuel proofing making it not truely fuel proof. At that point dope would work as well so would CA glue so long as you don't use high nitro.
