"The spec sheet for my charger stages that it charges 250mAh - 2000mAh batteries with a variable dial selector. I understand that the charge rate for any of the listed values is from .25Amps - 2Amps respectively.....is this correct so far? " YOU GOT IT
I just bought a Kan 1050 8 cell 9.6v pack so Im assuming that it is a 1050mAh pack? If I set my charger to charge approximately for a 1000mAh pack on my dial, Im charging around 1Amp till it detects its peak? ABSOULUTELY!
Yup you've got it figured out.
John
