RCU Forums - View Single Post - Laminar Flow
Thread: Laminar Flow
Old 07-26-2004 | 01:41 PM
LouW's Avatar
LouW
Default RE: Laminar Flow
As noted in the drag curves in my response above, it doesn’t take much camber to put the drag bucket in a most favorable position to cover both straight flight and steep turns. Everything else being equal, in positive “g” flight, a little camber always results in a more efficient wing. I think the prevalence of symmetrical sections (if that is the case) is a carryover from aerobatic design where inverted flight is a given. That is really the only place a symmetrical airfoil is the best choice.
(Whether some existing symmetrical airfoils operate in the drag bucket during steep turns is largely a matter of speculation. Moving the bucket to a higher lift coeficient would certainly increase the margin and might allow a little tighter turn. Every little bit helps.)
