RCU Forums - View Single Post - How Do I Remove Spring Starter?
Old 07-26-2004 | 02:23 PM
hilleyja
Default RE: How Do I Remove Spring Starter?
I'm not familiar with the US 41 but wonder if a simple small gear puller might do it for you. You can usually find one cheap at an auto discount store and/or rent one from them. My Fuji BT-50SA's spring starter assembly just slipped on over the shaft, one end of the spring slipped into a groove on the assembly and the other end attached to the crankshaft with a screw/washer.
