RE: Suggestions for first build
The Sig Four Star series of kits,(40 or 60 size), are an easy first kit to build and are also great fliers. With these kits you will need the bare minimum of tools, i.e. balsa knife set, razor saw, drill with various bits, glues,ca and epoxy. For finishing you'll need an iron and heat gun if you intend to use the iron on covering. Good luck
Bill
