RCU Forums - View Single Post - Engine Tuning Help!
Old 07-27-2004 | 06:00 AM
mk999's Avatar
mk999
Default RE: Engine Tuning Help!
Look, i've had time to think about this and on subjects like engine tuning it is down to personal preferance, IMHO the best way to tune an engine is on sound, smoke, heat and performance if you want to tune by pinching fuel lines and counting then fine if it works for you, use it, Stalefish you just need to try different methods to see what works for you, your engine and what you find easiest and most reliable.
Skyline350GT you can call me all the names under the sun i really couldn't care less, in your opinion I may have been wrong but i don't think that gives you the right to start throwing names around. Forums are all about discussing your opinions with other people sometimes there may be a right and wrong answer to questions like will xxxxx fit xxxxx buggy, in that case if i say yes it will fit and it won't then maybe you can correct me but I don't think at that point you can start throwing names about. Fine i may have made some mistakes recently I apologise once again for being Human we all make mistakes and maybe i did come across strong when i said it was innacurate, I apologise for that, maybe it isn't as inaccurate as i thought it was but once again it comes down to personal preferance and opinions and if you can't accept not everybody has the same opinion as you then maybe it is you that is in the wrong, I can accept that you tune your engine in a different way and you are protecting your opinion but i think you've gone a bit over the top about it and before you post another long bashing session towards me, think about it. If we can't at least be civil towards each other maybe we should agree to keep out of each others way and avoid confrontation.
