RCU Forums - View Single Post - How do you know you engine is running perfect?
Old 07-27-2004 | 06:04 AM
mk999's Avatar
mk999
Default RE: How do you know you engine is running perfect?
Maybe that's true but i ran my engine in a week ago it's had near enough to a gallon through it but i still can't turn the flywheel with my finger because of the pinch and compression and it is fully run in. I may be wrong but i'd say it meant that the 'traditional' method does a pretty good job[8D]
Edit:thanks for the explanation FaF was a little confused about that
