RE: O.S. LA Spitting props problem
Most four strokes now come with a lock nut type setup. Try putting two nuts on the shaft. The second after you've already tightened the first. Hold the first nut with an open ended wrench and put the second in place and tighten against the first. If the flat sides of the nuts line up the second is not tight enough.
