RCU Forums - View Single Post - Composite ARF Impact
Old 07-27-2004 | 04:46 PM
  #89
PeterP
Default RE: Composite ARF Impact
Morten,
How did Manfred's version compare to a current glow setup. I noticed from your original posts that his setup uses 2000mah. Is this adequate to fly a full F3A schedule. Are the outrunner setups more efficient than the Hacker / gearbox setups. I also noticed the propeller sizes are much different between the setups. I assume here that the actual gearing ratio of the Plettenberg setups is different to the Hacker 6.7:1.
Please provide any additional information if you have any.
Regards,
Peter
