Seagull Decathlon Engine selction??
hello everyone,
I just recently bought a seagull decathlon. Now I have 2 questions. The first is I want to use a four stroke engine. The maximum size 2 stroke engine is a 46. I'm thinking of using a 60 or 72 four stroke. I'm assuming the crank case dimensions are bigger on the lager four stroke. the problem is that the engine mount is already installed so do I have to replace the engine mount with a lager one? Has any one in the forum used a Four stroke in one of these planes? if so did you have to do any modifications?
Question #2- The kit requires a four channel radio with 6 servos. I already own a futaba sky sport 4 ch. Can I use my radio and buy 2 Y connectors or do I have to buy a computer radio?? Thanks for your time
Tim
