RCU Forums - View Single Post - Evolution Engine Trainer Prop.
Old 07-28-2004 | 03:35 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: Evolution Engine Trainer Prop.
I think you ought to try an 11-5 or 11-6 prop unless you just like the sound of high rpm.
The Evo trainer engine is a .46 and has the same bore and stroke as the Magnum .46, if you check the specs, so it should pull these 2 props very well. The Evo .46 is a longer stroke engine and its displacement rounds off to a .47.
