RCU Forums - View Single Post - Incidence question
Old 07-29-2004 | 01:36 PM
TuNeD PiPe's Avatar
TuNeD PiPe
Default Incidence question
Hi all
I am busy putting a new horizontal fin on my Stick 60 and want know what the effects are of adjusting the incidence of the horizontal fin. (i.e what will the effect be if the horizontal fin has a bit of positive incidence , will it pitch up or down?)
Previously I had just glued the horizontal fin without worrying about incidence.Before I had to fly with quite a bit of up trim which I think is becasue the wing's incedence was slightly negative.That I can fix if I have to, by putting foam under the front of the wing.But before I glue the new horizontal fin in place I would like to know wether I should give it a bit of negative incidence or just make sure that it is parallel to the thrust line and then adjust the wing's incidence to make the plane fly level.Before I had lost a lot of travel on the elevator because I think the incidence was not right.I know that the C of G may also effect the pitching of the plane,but that I have set to be slightly nose-heavy).
Thanks!
