RE: Amsoil 50:1 and 100:1 Temp diff in BME 102?
Many people run non synthetic oil in there 2 stroke engines and you can too, the down side is that over time you will probably accumulate more deposits in the engine as the synthetic oils tend to leave less carbon build up in the engine. If the engine is well cooled and not run too lean the life would be about the same as synthetic oil but the outside of the plane will have more oil on it to clean up.
flierbk
