ORIGINAL: ajcoholic
Thanks for the comment - I dont know how the wing loading would be, ie, would it be similar to your plane, heavier (and require more runway to land?) or what..
The ones that come in gray primer, I assume they are ready to paint? Or is there a lot of prep needed?
AJC
Andrew,
Due to the light wing loading on the Hawk, it will be very well suited for grass field ops. Certainly no issues at 600ft. The Robart gear can handle the loads and I have already had some discussions with Airpac regarding gear mounts. Rest assured, they will be beefy
The Gel Coat gray versions will only require the typical minor seam line clean up for painting.
DONT FORGET ABOUT THE F-5 GUYS! We need
your input on this one as well
