RE: ARF 4* .60, extra peices?
I had the same assortment of parts left over. I used wider fiberglass than came in the kit to reinforce the wing joint. If you haven't already, solder any part of the the throttle cable that doesn't enter inside the cable housing at the extreme travel in each direction.
