RE: OS 61FX Engine Problem
Bill there shouldn't be any air bubbles in the fuel line between the carb and the needle at all when the engine is running if this is so replace the fuel line and try again also double check the fittings as well. as far as break in mine was a biatch to break in it ran great on the ground nose up check fine ,take of and the engine would stall so now i run it a little fat until it breaks in good luck Bill
