RCU Forums - View Single Post - sealing control surface
Old 07-22-2002 | 07:40 PM
latch66
Default sealing control surface
I use the packing tape or the same covering which I used on the airplane.
If you wanted to use a clear covering it will work. Just make sure to not try to tack a high temp. covering for the seal on a low temp. covering scheme on the airplane.
