Darn,
I started on the same plane then moved to a SIG LT-40 Kadet then a SIG 4 * 40 ARF (Lands better than the Kadet and Xtra Easy 2) and also bought a Twist
World Models makes a good low wing and high wing plane for around 70 bucks that all your equipement will work well with
The high wing is a semi symetrical airfoil and is a trainer. The long wing is a fully symetical and can do nice aerobatics
They are the Sky Raider I (High Wing) and the Sky Raider II (Low Wing)
The Hangar 9 Ultra Stik is also a good choice but you will need to by at least one more server and if you want the flaps optin the you will need a total of 3 more servos (JR 537 servos are fairly cheap
http://www.sigmfg.com/cgi-bin/dpsmar...FV3.html?E+Sig
http://www.theworldmodels.com/para/p...?airplaneid=68
http://www.theworldmodels.com/para/p...?airplaneid=69
http://horizon.hobbyshopnow.com/prod...675&pc=HAN1675
If you can afford it I would suggest that you keep the trainer handy and intack and purchase a new engine from evo, the NT46 is around 80 bucks and a JR Airpack with the correct channel for the receiver crystal, usually 5 bucks for the crystal and 125 for the receiver and 4 servos
this one will work well with the radio you already have
http://horizon.hobbyshopnow.com/serv...=ALL&tag=qsrch
The four star and world model planes use 4 servos and the utlra stick can use 5 to 7 servos depending on your desired setup but will only need 5 channels
